FS: Picked up another 90 awd talon for parts white 5 speed
thedsmguy
Vancouver Washington
White, 16" gst wheels decent tires. 5 lug swap (edit... 5 lug stuff to swap your galant if wanted). downpipe 2.5" transmission grinds a little into 2nd when pushed hard and not warmed up but everything works. Good crank, rebuildable block, ecu etc.. I've also parted out about 25 other dsm car so please ask for anything I have.
thedsmguy
I try to buy them all. /ubbthreads/images/graemlins/devil.gifThey are not chromies. I did however see a set on the dsm tuners trader, almost for sure to be closer to you then me! Good luck with your hunt!
WiSu
Northern VA
Crank doesnt need to be cut or anything correct?
How much shipped to 22312?
WiSu
Northern VA
PM'd about the crank.
Thanks for the fast reply! /ubbthreads/images/graemlins/smile.gif
thedsmguy
If you want just the hubs front and back they fit in a large flat rate postal box, but I think they would be over the weight limit (20 lbs international) that they allow. But then again, I've never actually weighed them as I send them out flat rate all the time.
I'd sell a 90 tranny for $250. I have a 90 awd welded diff tranny 98k miles for $300 as well (different car).
