FS: Performance parts off my 1G...Now w/ pics
NateCrisman
Blairstown, NJ
EDITED: 7/7/14
Parting out my 92 AWD Auto DSM (red talon)... /ubbthreads/images/graemlins/bawling.gif No motivation to continue on with DSM stuff lately, and Iv moved on to a new "toy" car (Dodge Magnum SRT8 w/ blower). /ubbthreads/images/graemlins/devil.gif
this car went 10.7@128 on this setup w/ E85 in Fall of 2013. The car has been sitting on my lift since that day, due to an oil leak in the front case that developed on that run.
Please email me at [email protected] . I don't get much chance to check forums much anymore. Parts located in Blairstown, New Jersey 07825. Will negotiate shipping costs based on location and size/weight/packaging pita. Cash/Pickup encouraged!
Anyway, here is the list:
ARP head studs. $45
ABS Delete set (prop valve & 4 lines) $85
forward facing 6bolt oil filter housing $25
1g dsm radiator: $20
non turbo throttle body: $20 (no sensors)
valve cover $50 no cracks
alternator (rebuilt and clean) $50
CAS (91-92 green top) $35
91-94 coil pack $35
MPI relay $10
Front subframe w/ control arms. $50 ?
single piston front brake calipers w/ hoses $50
92 dsm headlighs: $30
92 dsm corner lights: $20
92 dsm turbo auto gauge cluster $15 135k miles.
GVR4 specific stuff:
4 lug front hubs: $50
4 lug front brake rotors for single piston calipers...GGSX I guess $50
$150 KYB GR2 shocks w/ Eibach prokit springs
Unorthodox crank pulley for 6bolt. $25
grant steering wheel $20
rebuilt 2G cyl head. Stock valves, valve train, lifters, rockers. $250. Ready to rock.
Apexi Catback 1g awd exhaust w/ slip fit test pipe. (minor surface rust on pipes, muffler is in pretty poor shape w/ a rust hole on bottom) $120
Spearco liquid/air intercooler "the crab cooler" w/ aluminum ice water tank, hoses, rule bilge pump....$385
Pic of water tank/pump coming soon.
3" intake pipe w/ air filter in fender (gotta cut hole where stock ic pipe goes) $65
SOLD
Megan Racing 3" Stainless Downpipe $100
DSMlink V3 w/ Eprom 92 ECU. $450
HKS 272 cams (nice condition...real HKS) - $280
FIC EasyTune box (think this bumps voltage to injectors to help with tune)... $155 shipped
FP exhaust manifold $125
AEM boost control solenoid $
AEM 5bar SS map & AIT Sensor (w/ plugs) $85
Aeromotive FPR w/ -6 SS hose to rail, pressure gauge, rubber hose to oem return pipe. $145
Walbro 255HP in tank pump $45
Autometer vac/ 45psi Sport Comp boost gauge $40
Fp3065 turbo, o2 housing, oil/water lines. $1050
Tial 44mm external. $185
FIC 1650s. $375
Evo3 intake manifold $130
MT ET Drag slicks (stupid cheap)
igniter/TPS
Front crossmember - Tube
JMF coil bracket
6Bolt bottom end, 1 2g head, AWD DSM fuel tank & sender, rear awd subframe assembly
2.3L stroker assembly
Tial bov replica
Konig 16" wheels and tires
Ingall control arms
Bosch 044 pump and -6 lines
second auto set
forced four shift box
TCU MD750092 : $100 (automatic trans computer from 92 awd)
ISC motor
VOLK wheels
Innovate wideband
ARP headstuds
Fluidampnr crank pulley
NateCrisman
Blairstown, NJ
I got a lot of emails from late last night and today to go through once I get home to a real keyboard. Will respond to everyone, and post up pictures of parts.
Thanks for the interest!
Damn, some good deals there. Too bad I don't need anything. /ubbthreads/images/graemlins/frown.gif
ghostinthevr4
Fresno, Califonia
Quoting DSMRonin:
Bummed I haven't received a response yet? /ubbthreads/images/graemlins/dunno.gif
I haven't received a response either I sent a P.M. and a email and got no response.
EgonOlsen
Denmark, Europe.
I got a response today indicating he got a LOT of emails and he havent sorted them out yet.
But I dont think any of you are forgotten yet. /ubbthreads/images/graemlins/smile.gif
NateCrisman
Blairstown, NJ
Yeah guys..insane busy. In middle of selling my house and buying another one...inspections and mortgage pita. Should be closing and moving August 4, we are starting to pack up the household now too, as well as planning rnovations to the new house. Job is a hassle, kids are home from school. Ect ect
NateCrisman
Blairstown, NJ
Haven't even looked at Pm's yet either, gotta do that.
Plus gotta get the "dirty" parts cleaned up and photos done of the bigger stuff (motor/driveline).
Plus gotta fix my new magnum....had to send the custom rear axles out to IL for rebuilds, these things are monstrous, they make the dss axles for Dsm look like toothpicks. Supposed to be strong enough for 1400hp drag setup. Itching to get to modding the new car...gotta add gauges, logging setup, meth kit, and buy a set of rear wheels and slicks. Gotta see about inspection, then removing the cats and putting wideband sensors in the mid pipes so I can tune & run racegas.
