FS: Injector plugs, 3g 1-1/16" MC, 501 mafs, ISC,coils Updated 7-27
89Mirageman
Stantonsburg, NC
Quick release injector plugs. I have 8 sets of these (set of 4), $10 shipped for 1 set of four in the US.
501 maf with plug $5 + shipping (11 available)
609 2g maf with plug $10 + shipping (3 available)
3g Eclipse 1-1/16" bore MC $25 + shipping (6 available)
Black ISC motors $28 shipped (5 available)
Intrepid coils with plugs, these have the mounting holes directly across from each other.
All SOLD
I found a few sets of the other coils, these have one mounting hole on top and one on the side. ALL SOLD
2g dsm valve cover, two tiny cracks. I tried to get pics but they wouldn't show. Can easily be repaired and sanded smooth with JB Weld and painted. No stripped threads. $8 + shipping
1g dsm 91-94 shifter with boot (2 tiny holes,otherwise looks good)& knob SOLD
Shipping on the maf's and MC will be $12.35 more than likely using a medium flat rate box. If you live a little closer to NC PM me and I'll try to get a better price.
Paypal is [email protected]
Bump for a great guy to do business with. I installed a set of the quick release injector plugs I got from Chris and they are a million times better than removing the little metal clips and breaking the plastic tabs every time you want to pull an injector. Best $10 bucks you'll ever spend. They look nice too /ubbthreads/images/graemlins/grin.gif
I also got my 3G master cylinder from Chris. It cleans up the firewall and gives you great pedal feel. In short, you need his parts!
KiNgMaRtY
Corona, CA
Are any of the 3g Masters Cylinders ABS? We need them to be ABS if we plan on keeping the ABS correct?
manikbastrd
Are these Coil on plugs bolt on + wiring? Basically will it take me more than a few hours to install? Also, Do you have any pics installed?
89Mirageman
Stantonsburg, NC
Quoting KiNgMaRtY:
To my knowledge there is no difference between an abs or non abs M/C other than the bore and piston size. ABS seems to be a separate unit with its on ecu and sensors to run it. But to answer your question I honestly don't remember. I just make sure they have the 1-1/16" bore and come from a 3g eclipse when I pull them at the JY.
