FS: GVR4 ABS Delete Kits @ JNZ Tuning!
DSSA
PA
I've been a slacker and sitting on these for a while, but over the winter I measured up lines/fittings for an ABS Delete for the GVR4s while Nate's car was in the shop and I had one to measure.
Please note that these are lines to replace the ABS hard lines and terminate in the wheel wells to work with your existing SS caliper lines.
Details can be found here: click
GVR4 member introductory pricing (please verify your forum name when ordering) is $169.99.
Thanks!
Josh
MX4
New Zealand
For anyone thinking of ordering from JNZ. I have made multiple orders through them and have had nothing but excellent service. I have always ended up dealing with Paul and he is great to deal with.
kooter
carpentersville, IL
I will third that one, paul is very friendly and helpful. He helped me out alot when I placed a couple nice sized order's not too long ago.
DSSA
PA
Quoting blacksheep:
^^^ Cold-ass honky right thurrr. Dropping bombs like dat, yo! Bubba for Prez!
Ha! KC
Pick one up man, you'll thank us later. /ubbthreads/images/graemlins/devil.gif Tell Paul Mike Valencia said Hi. /ubbthreads/images/graemlins/grin.gif
rmontalvo23
Fort Lauderdale, FL
I have a set of 3000GT VR4 calipers that I am going to install. Do I need anything extra or do I need the proportioning valve also?
Please let me know, I need this delete kit.
PC_Talon
Member
Lansdale, PA
Rich,
Pretty sure I sent you an email regarding this, but figured I would post on the board in case anyone has a similar question.
I am pretty sure the 3000GT uses the same flare fitting 1G/E39A calipers use. We could make the lower portion of the stainless lines an inch longer to offset the difference of the larger rotor/caliper combination.
I know it has been a point of discussion of the 1G AWD Big Brake non ABS Prop Valve not being the optimal solution for the Galant application.
If anyone has any suggestions that they think would work better please email or call us at the shop.
Thanks,
Paul
Scientist
Roseau/Dominica
JNZ is an amazing shop to deal with. been dealing with them for a few years now with no issues. Too bad i'm doing my brake lines behind the firewall
DSSA
PA
Thanks for the kind words!
Just as a side note, if you need to have custom lines made up, we can have them made. It just takes a week or so lead time to get them to make them for us.
I actually had him make one-off stuff quite a bit before; from window lift cylinder line for my '47 Lincoln, to MIVEC feed lines to custom fuel lines for GVR4s.
