FS: Garret GT3076R bb turbo SOLD
Gtpdz
Gig Harbor, WA
Selling a Garret .60 A/R compressor housing and .63 A/R turbine housing Gt30r bb turbo, comes with a custom built O2 housing and DSM flange, and all the hardware for a near direct bolt on including manifold bolts and 3AN oil feed and 10AN oil drain lines. The O2 houaing has a similar flange as an EVO3 housing and bolts onto most 3 inch downpipe.
Turbo was from a good running car, going for a smaller setup so no longer needs that, it's always been running waste gate pressure which is around 11 psi. Does not smoke or burn any oil, compressor outlet still shiny, normal side to side shaft play for a bb turbo, it will keep spinning for almost a minute after car is shut down.
Sold, thanks for the interests.
mitsuturbo
Near Seattle, Washington
Nice!
Thanks. That confirms this is the newer version of the GT3076R. (there were like 6 versions, before) Great price on that. I almost decided to buy it myself. /ubbthreads/images/graemlins/smile.gif
Gtpdz
Gig Harbor, WA
Much appreciated for the interest, just wonder can you provide the source of this information on the tag numbers? Thanks.
