FS: Fidanza, ford 8.8, 3 bolt LSD axles, 14B, t-case, intercooler, foglights, etc...
1941Galant
Charles Town, WV
Fidanza Aluminum flywheel. Step height is within spec. It comes with longer flywheel bolts and the AWD plate. $70
Stock 3 bolt LSD axles. Appear to be in good shape. $50
14B turbo off of #1414. Around 143k miles, it spooled fine, but the exhaust housing is cracked. Some side to side play, I cannot detect any in and out play. $50
22 Spline transfer case also out of #1414. Around 145k miles, it worked fine. All aluminum housing - $75
Spearco AWIC Intercooler. I bought for a project years ago, but have no use for it. It appears to be in decent shape. 3" inlet/outlet $300
Stock foglights w/ brackets. Good condition $90
Evo rear seats, a little dusty but otherwise good condition $50
1g Blow off valve, uncrushed $50
Injector resistor pack $20
Fuel pump relay $20
Knock off tial BOV, seemed to work fine $40
Ford 8.8 rear axle, 2.73 gears, LSD, disc brakes, 4 link brackets, needs seals $150
4 lug wheels, can't remember the make, look good on VR4. Need tires $250
5 lug borbet wheels, kind of old school. 5x114.3, unsure of width or offset. came off of talon. They also need tires $200
Stock unmolested cylinder head. 143k miles, came off of #1414, and is in decent shape. I needed a few valve locks for the upgraded head that I put installed on #1414. $200
Not pictured are a full set of interior door handles without peeling chrome - $40
