BluFalcon
Cleaning out some stuff around the garage, and found some items I don’t really want or need , so it’s for sale. Prefer a local buyer, but I will ship at buyer’s expense, unless otherwise noted. You've seen my Goodguy thread, and all that gushing praise still applies. If you want to use Paypal, that's fine, but tack on another 2.9% if you don't want to send payment as a gift.
1.<b>*SOLD*</b> 90-91 DSM Light Set- Extremely Clean Set Of DSM Parking Lights and Corner Lights. No Cracks, Broken Tabs, Or Oxidation. Probably The Cleanest Set of These Lights I’ve Ever Found. -$50 For The Set (Will Not Break Up Set) <b>- SOLD!</b>
2. 90-91 Eagle Talon Center Grill- I Have Two Of These In Black. Good Condition, With No Cracks Or Broken Tabs On The Body Of The Grill. The Talon Badge In The Center, Does Show Signs Of Pitting And Wear, But Still In Serviceable Condition. -$25 Each
3. <b>*SOLD*</b> 1G DSM FMIC “Race” Core- Core Was Sold By DSMotorsport As Part Of Their Race FMIC Kit. The Core Is A Genuine Spearco 2-216 Core, With Endtanks And 2.5 in Outlets For Short Route FMIC Piping. The Core Is Slightly Dented Because A Previous Owner Forgot How Low The Car Was. Purely Cosmetic Damage. I Have A 2.5in SS Cold Side Pipe Flanged For a Tial BOV, And A 2.5 in 90 Degree Aluminum Elbow That I Will Include With The Core. -$275
4. Magnus Billet 4G63 Reusable Oil Filter- I Bought This A Few Months Ago, And Decided I Really Didn’t Need It. Reusable Oil Filter With A Cleanable SS Filter Element. Element Can be Removed For Inspection And Cleaning. Never Used, Just Been Rolling Around In A Box For A While. Includes Fixture To Properly Disassemble And Reassemble Filter. -$110 Shipped
5. JMFab SS Exhaust Manifold Heatshield- Cutout For SB Racing Manifold With External Gate. Stainless Steel, Polished. -$40
6. 4 Bolt Axles- Spare Set Of 4 Bolt Rear Axles. I Believe These Are For A 1G Rear End, But Can’t Be 100% Sure As I Found These Loose In A Shop That Was Closing Up. I Have A Single Axle As Well, Which Can Go With the Set. Prefer Local Sale Only- $50 Set
7. HKS Throttle Body Elbow- Cast Aluminum, With Approximately 58mm Inlet/Outlet. Good Condition. Would Work Well With The Cold Side Piping I Have For Item #3. - $60 Shipped
8.<b>*SOLD*</b> 90 Throttle Body- Complete 90 Throttle Body With All Plugs And Sensors, With Additional Incomplete Throttle Body For Parts. -$25
9. 2G Prothane Inserts- 13-502 Front Roller And 13-504 Rear Roller Inserts. Red, Brand New In Packaging. $20 Shipped.
10.<b>*SOLD*</b> Old School HKS Wastegate- Gate Outlet Seat Measures Approximately 44mm. Old, Rusty, But Works. Ops Checked Fine. Small Grind Mark On Diaphragm Body , Between The Upper And Lower Halves. No Additional Flanges,Gaskets Or Hardware. What You See, Is What You Get- $50
11.<b>*SOLD*</b> Knock Off Greddy Type-RS BOV- Got This Fake Greddy BOV Recently With Some Spare Parts, And I’m Tired Of Looking At It. Includes 2.5 in Adaptor Pipe With BOV Flange. Probably Made Out Of Shattered 10 Second Dreams.- $20
12. HKS SSQV BOV- Got This In A Box Of Parts, After It Had been Disassembled. As Far As I Know, It’s A Genuine HKS Unit. Needs Hardware To Bolt The Cover To The Plunger Seat And BOV Body, Also Needs A New Nipple For The BOV Body. Includes Aluminum Weld On BOV Flange And Recirculation Fitting. Pick Up A Knock Off BOV For Parts, And You Can Put This One Back Together. -$20 Shipped
13. 76mm Accufab Throttle Body- Mustang Accufab Throttle Body Modified For Use On a DSM. Includes DSM Throttle Linkage On Shaft. I was Told This Throttle Body Leaks From The TPS Sensor, So That’s Why It’s Cheap. -$75
14. Autometer 1G DSM 3 Gauge A-Pillar Pod- 3 Gauge Pod, With Two Pods Opened Up For 60mm Gauges And One Single Pod For A 52mm Gauge. -$20
