FS: 95 5 speed eprom ecu. SOLD
thedsmguy
Vancouver Washington
The other ad reminded me that I too have a 95 eprom ecu from a 5 speed car. Not sure what these are worth so if you need a 5 speed specific one PM me.
Thanks
Sold for $150 for reference.
4wheelsqueal
Shawano,WI
Ill ask the same questions as I did on the 95 auto eprom thread. Any work done on the board? Caps replaced? Has it been opened up at all?
thedsmguy
I think in a 2g they use the same injector size for auto vs 5 speed and fwd vs awd so I think it would work, There might be slight differences in timing curves?
VR4Scott
Orlando, FL, USA
The 2g's all use the same injectors. 5 speed and autos use the same ecu. A awd ecu will work in a fwd, and a fwd will work in a awd. A 95 eprom ecu will work fine in a 95-96. If you put a 95 eprom ecu in a 97-99 car, you need to swap the spark plug wires and injector plugs.
1 becomes 2
2 becomes 1
3 becomes 4
4 becomes 3
Reason being the cam sensor is on the opposite side of the head. There are very minor differences in the awd vs fwd programming. The awd does not have speed cut, the fwd does. The awd rev limit is a little bit higher, like 300 rpm, and a couple other things. The differences are so minute, most would never notice the difference.
BTW $150 is a steal for a clean 2g eprom ecu. I mainly part out 2g's and have sold several of these ecu's from $150-$250. GLWS.
thedsmguy
I know it is a great deal. I'm just trying to get a little cash for my upcoming move and nothing much seems to be selling /ubbthreads/images/graemlins/frown.gif
