Brunoboy
Hey guys, I'm really sad to say this but at the moment I am forced to sell 556/1000. It is a KG with 204,xxx miles. It is on non OP and needs to be towed. Compression was low in cylinder one and I had pulled the motor apart to find a melted piston. All the parts are there for the motor. It is a CLEAN CA TITLE and is all stock. I have sold the stock inter cooler and piping along with the stock injectors. Balance shafts were removed and has new oem timing belt and tensioner, water pump and new gaskets. Interior could use some clean up as it's missing the Bpillar on the driver side and dash has a bit of lift. Body has dings and few dents but has no rust. One fog light is cracked as well. Previous owner "circuit" here has had it in his family for the past 11 years and I picked it up with intentions of rebuilding it. $1500obo.
