FS: '91 Gvr4 Partout (xxxx/2000) NB *Updated September 11, 2022
pot
Fayetteville, NC
FS is everything from an unbadged non-sunroof 1991 Galant vr4. This Galant has 151,910 miles on the odometer and was originally Nile Black.
All parts prices include PayPal fees & Shipping Costs for CONUS based transactions. First come first served.
I accept all payments via PayPal to: [email protected]
For inquiries please contact me via PM or mobile no (910) 689-6150. Thank you for looking!
ENGINE
Camshafts, Stock $35.00 each
Cam Cap Bolt Set $20.00
Rocker Arm Set $25.00
Crank Pulley Bolt w/ washer $12.00
Water Pump Pulley Set $20.00
Resistor Pack $40.00
Fuel Rail Bolt Set $3.00 plus shipping
Fuel Feed $8.00 plus shipping
Lower Rear Timing Cover $15.00
Rear Upper Timing Cover $15.00
Banjo (Coolant) $3.00 plus shipping
BOV $25.00
Harmonic Balancer Bolt Set $3.00 plus shipping
EVAP Line *Connects to Charcoal Canister $5.00 plus shipping
BODY
Headlights $125.00 for the set or $65.00 each
Cowl Panel $80.00
Front Windshield Side Trim *Passenger $20.00
Hood Latch $15.00
Horn $15.00
Cowl Panel Trim $8.00
Front Driver Dogleg $60.00
Hood Release Cable Guide $12.00
Radiator Fan $20.00
Windshield Wiper Set *Driver Air Spoiler missing $35.00
Fuel Filter Bracket $3.00
Hood Release Cable $15.00
Throttle Cable Guide *On Passenger Strut Mount $3.00
Exhaust Hanger $8.00 each
Rear Window Regulator $30.00
Front Driver Interior Door Wiring $30.00
Door Sensor Set $25.00 or $10.00 each
Door Latch Set $20.00 or $8.00 each
Rear Passenger side Quarter Window Glass $50.00
Rear Driver side Quarter Window Glass $50.00
Fuel Door $20.00
Fuel Door Cable $15.00
Trunklid Ajar Switch $8.00
Roof trim Clips Set $8.00
Rear Top Window Molding $40.00
Rear Bottom Window Trim $50.00
Trunklid Catch $5.00
Rear Decklid Wiring Harness $30.00
INTERIOR
Dashboard Vent $2.50 each
Dash Speaker Cover *Only Driver side is available $20.00
Hood Release Lever $8.00
Horn Pad $20.00
Glove Box Frame $15.00
Glove Box Striker $5.00
Glove Box Reinforcement Bracket $3.00
ECU Tray $12.00
ETACS $40.00
Chassis Control Module part no MB801352 *Alarm $40.00
Driver Side Visor $15.00
Mirror Cover $8.00 (Non-Sunroof)
Outlet Bezel $15.00
Shift Cable Clips $1.00
Retractor Mounting Bracket $40.00
Control Unit Auto Seat (Part No MB617345) $25.00
Seat Headrest $30.00
Seat Height Adjustment $5.00
Seat Hardware Cover (Driverside) $8.00
Amplifier & Radio Antenna Cable $30.00
Gas Pedal $30.00
Clutch Pedal $50.00
Clutch Interface Switch $12.00
Clutch Switch $12.00
Stoplight Switch $12.00
Front Seat Hardware Set $2.00
Front Passenger Door Speaker Cover $20.00
Driver side Speaker Cover $20.00
Door Knob Trim $.50 each
Door Handle Backing $3.00 each
Interior Door Pull Handle $8.00 each
Oh sh*t Handles $5.00 each or $15.00 for the set
Driver Window Switch $40.00
Front and Rear Passenger Window Switch $12.00 each
Door Card Clip $1.00 each
Front Passenger Rear View Mirror Trim $3.00
Driver Door Handle Deadpanel $5.00
Rear Door Ashtray $8.00
Doorcard Light $8.00 each
Front Scuff Plate $12.00
Passenger Rear Scuff Plate $12.00
Driver Rear Scuff Plate $12.00
Ash Tray $12.00
HVAC Bezel $30.00
HVAC Knobs $1.00
Buzzer $5.00
Center Console Side Panel Insert $15.00
Trunk Dome Light $8.00
Rear Driver side Seatbelt $25.00
Rear Defroster Heater $5.00
Trunklid Hinge Stay Set $15.00
STEERING & SUSPENSION
P/S Reservoir $30.00
Lower Plate & Stopper Set *Front Subframe $5.00
P/S Rack Mount Bracket $12.00
Front Passenger Control Arm $30.00
Clamp $15.00 each
Front Swaybar Brackets $12.00
Swaybar Endlinks $12.00
Rear Steering Rack Mounting Hardware Set $3.00
Rear Crossmember Mount $30.00
Rear Driver Upper Control Arm $20.00
Rear Upper Passenger Control Arm $20.00
Rear Shock Dust Cover $5.00 each
Rear Shock Mount Bolt Set $3.00
Rear CV Axles $40.00 each plus shipping *One left
Rear Lower Control Arms $25.00 each
3 Bolt Cups $20.00 each
BRAKES
Brake Master Cylinder $15.00
Front Driver side Brake Line $15.00
Rear Brake Caliper Brackets $20.00 each
Parking Brake Retainer $3.00
ABS Motor $75.00
ABS Proportioning Valve $15.00
Front ABS Sensor $20.00
ABS G-Sensor, Front $20.00
ABS G-Sensor, Rear $20.00
Electronic Control Unit (ABS) $40.00
ABS Connector Bracket $3.00
Brake Fluid Reservoir $12.00
Brake Line Mount $3.00
DRIVETRAIN
Flywheel Bolt Set $8.00
Pressure Plate Bolt Set $3.00
Clutch Line to Slave Cylinder $8.00
Stainless Clutch Line $12.00
22 Spline Transfercase $150.00
Center Yoke $15.00
Rear Propeller Shaft Bolt Set $3.00
Rear Differential Bolt Set $10.00
Lostkoz
Active member
Boise, ID
Looking for the weather strip that sits in between the front windshield and roof of the car. Also need the driver side rear plastic 1/4 panel piece(not sure of the specified name. I can post a pic if that helps.
4Grim
Orlando FL
Hey Pot...just PM'ed you a part I need.
Thanks man. /ubbthreads/images/graemlins/cool.gif
youngbuz
New member
sydney
hello im from sydney australia and need the rear bumper asap how much are you looking for ????
E39_VR4
Member
Lenoir City, TN
Need headliner board and the two small lower trim panels on each side of the console. Would you by chance have the complete seat bases,just the sliders and all the associated mechanisms, with the trim panels? Don't need the seats themselves. Please PM with prices and availability. Thanks!
