pot
This is a part out for the following vehicle:
- 1991 Galant vr4 badge number 560/2000
- VIN: Unknown
- Model: E39ASNPFL2M
- Color, Interior Option: X68
*All parts prices include PayPal fees and shipping costs for CONUS based transactions. I accept all payments via PayPal to: [email protected]. If interested please contact me via PM or mobile no (910) 689-6150. Thank you for looking!
Injector Resistor Pack $40.00
Relay Set $25.00
Alternator Relay $12.00
Cowl Trim $8.00
Door Striker $8.00 each
Door Wiring Harness $40.00 each
Door Ajar Sensor $12.00 each
Door Lock Relay (part no MB543647) $12.00
Front Door Lock Actuator & Latch Assembly $25.00 each
Rear Door Lock Actuator & Latch Assembly $25.00 each
Door Handle Base $12.00 each
Outside Door Handle Cover $8.00 each
Door Molding $65.00 each
Rear Window Regulator $50.00 each
Chassis Control Module (part no MB801352) $40.00
Control Unit Auto Seat (part no MB617345) $40.00
ETACS Computer (part no MB852353) $50.00
Timer Unit Defogger (part no MB572253) $12.00
Driver Quarter Glass $50.00
Passenger Quarter Glass $50.00
Fuel Filler Door $20.00
Fuel Lid Latch $8.00
Trunk Lid Wiring Harness $40.00
Fuel Pump Wiring Cover $15.00
Passenger Rear Tow Hook $25.00
Wiper Arm $20.00 each
Horn $12.00 each or $20.00 for the set
Hood Latch $15.00
Hood Release Cable Guide $12.00
Hood Alarm $8.00
Hood Dampener Set A : $5.00
Hood Dampener Set B : $3.00
Clutch Pedal $50.00
Brake Pedal $40.00
Gas Pedal $40.00
Driver Foot Rest $15.00
Brake Light Switch $15.00
Clevis Pin $5.00
Hood Release Lever $12.00
Passenger Dash Speaker Cover $15.00
Passenger Door Speaker Cover $15.00
HVAC Control Panel $30.00
Buzzer (part no MB561626) $15.00
Radio Antenna Cable $20.00
Front Door Sill Set $20.00
Rear Door Sill Set $20.00
Center Console Trim $15.00
Door Card Hardware Set $3.00
Door Card Retainer $1.00 each
Door Card Light Set $5.00 each
Interior Door Handle $8.00 each
Door Handle Backing $5.00 each
Front Lap Belts $20.00 each
Rear Shoulder Belts $20.00 each
Rear View Mirror $20.00
Window Switches $8.00 each
Rear Seat Arm Rest $40.00
Rear Speaker Cover $20.00
Non-Sunroof Dome Light $30.00
Trunk Access Trim $15.00
Trunk Trim $20.00
Trunk Dome Light $8.00
Clutch Line Bracket $8.00
Clutch Line to Slave Cylinder $12.00
Flange Yoke to Differential Hardware Set $5.00
Front Driver Brake Lines $15.00
Rear Brake Line Set $15.00 each
Brake Fluid Reservoir $20.00
Parking Brake $50.00
Parking Brake Adjuster $15.00
ABS G-Sensor *Front $30.00
ABS G-Sensor *Rear $30.00
Front Swaybar Bracket $15.00
Rear Lower Control Arm $25.00 each
Rear Crossmember Bracket $20.00
Rear Upper Control Arm $20.00 each
Rear Strut Mount $15.00 each
Rear Swaybar Bracket $15.00
Auto Comp Controller (part no MB276780) $30.00
Harness, AC Thermostat (part no MB276781) $20.00
Blower Motor $65.00
Cooling Unit $65.00
Heater Unit $65.00
HVAC Vent Adjuster Tab $2.00 each
- VIN: Unknown
ENGINE
Engine Mount Bolt $8.00
Relay Set $25.00
BODY
Air Inlet (Passenger Side) $15.00
Cowl Trim $8.00
Hood Latch $15.00
Hood Alarm $8.00
Clutch Pedal $50.00
Brake Pedal $40.00
Gas Pedal $40.00
Clevis Pin $5.00
Trunk Trim $20.00
DRIVETRAIN
Clutch Master Cylinder $20.00
BRAKES
Non-ABS Brake Lines *Missing one $85.00
STEERING & SUSPENSION
Front Control Arm Clamp $25.00 each
HVAC
Blower Motor $65.00
Cooling Unit $65.00
Heater Unit $65.00
