FS: 2G exhaust mani, GVR4 o2 housing, front case, ex mani
matt92vr4
Venice, FL
EVERYTHING IS OBO
Hello, I have a couple parts off of my GVR4 for sale. PM me if interested.
SOLD 14B turbo. Cracked hot side near the WG flapper. Leaks internally. Does not leak externally. VERY little shaft play dry. Turbo ran fine at 17psi. No leaks or smoking. It was laggy due to the crack. Fully spooled at 4300RPM. WG has a dent in it. This would be a great turbo for someone who is looking to get their car running cheap and needs a turbo to use for awhile. $75 shipped to lower 48 USA. SOLD
Stock GVR4 exhaust manifold. I found one small surface crack. It doesn't look like it goes all the way through and cannot be seen by the camera. It was not leaking. $25 shipped to lower 48 USA.
Stock GVR4 o2 housing. Good shape. $20 shipped to lower 48 USA.
Stock GVR4 front case housings used. This is the old one that came off when I rebuilt the motor. It's dirty and does not come with gears. Housings only and I do not have the bolts for the small gear housing. Not cracked, did not leak. I don't know if anyone wants this but I suppose if someone is in a jam it could come in handy. $20 shipped to lower 48 USA.
2G exhaust manifold. Ported where the turbo bolts on. Has two holes drilled in top for sensors. One of the holes is plugged. One of the heat shield bolts is busted off. I bought this to put on my car but the seller neglected to mention the holes drilled in the top. I didn't feel like messing with it so I bought another one. $50 shipped to lower 48 USA.
Thanks for looking - Matt
