spooln4fun
Car:1993 Eagle Talon TSi AWD
5Spd with lsd rear end
White with black leather
108,xxx miles
Reason for selling-I'm getting married and could use the extra funds. I had this up for sale a while back and decided not to sell it. Car runs great and has never left me stranded. Car is currently stored for winter (I just dont drive it in snow)but can be gotten out and seen at any time. I have listed everything I can think of and have taken pictures of all things mentioned and what I belive most people want to see. If you need certian pictures or have any questions feel free to PM here, then I'll give you my cell number where you can text me or call me.
The Bad- Valve seals are starting to go bad I think
There is a one ding in the front driver fender and 2 in the pass rear quarter(will post pics of this)
The driver side seat has a tear in it.
Passenger side door has a piece missing from ground effect
Cruise control doesn't work and I belive it is the switch on the steering column
The Good- Headliner doesn't sag
Keyless entry
I have owners manual and factory window sticker for vehicle
Has both aftermarket wheels(2 great tires, other 2 need replaced and I have replacements for them) and factory wheels(with new tires)
Alignement done in november.
Mods: Evo Suspension with Tien lowering springs
DSMLink V3 lite
Evo gauge cluster under radio (Boost, Oil Temp, Voltage) all working
Drop Engineering Mounts
Revised Lifters
3" turbo back exhaust
Ebay DNP tubular style exhaust manifold
Symborski shifter kit, solid aluminum shifter bushings in end of cables, shep shifter cable bracket bushings.
Maintance: New timing belt, tensioner, water pump, pullies(including balance shaft) Done less then 10,000 miles ago
New Clutch, front axles,sway bar links, at 94,000
Will need oil change soon
108,xxx miles
Keyless entry
DSMLink V3 lite
Revised Lifters
