FS: 1992 VR4 998/1000 in FL with JDM ( Super clean car) SOLD
boostx
Orlando, FL
SOLD
Posting this for dmj. If need more info PM him @ dmj
Up for grabs is one of the CLEANEST vr4 around. This car is 99.9% rust free. The pictures does not do this car justice.
He will be adding the details on the car.
Every bushings on the car that can be replaced have been replaced.
Rebuilt engine
All new front end parts and a lot more.
More info to come
3rdstrikedsm
32159, FL
Yes I have seen this car in person and it's stupid clean, John why did you not tell me it was going to be for sale? I said I had no interest in owning another gvr4 but this one would make me seriously re think that /ubbthreads/images/graemlins/devil.gif
Jesus_Negros
USA
Very sexay gvr4. Glws hope you get asking price.
dmj
orlando FL
Ok .sorry for the delays I have been busy for the last few days and will have a comprehensive list of what was done to the car and more pics of the interior and undercarriage of the car as soon as time allows most likely by Wednesday am.
dmj
orlando FL
more pics
Bottom End
Stock Bottom end Now just north of 13,000 miles
New Oem Balancer 1,127 miles
New Oil Pan 1,127 miles
Balance shafts Removed 1,127 miles
New OFH Saa
Head:
EVO 9 valve springs
EVO 9 Aluminum retainers
HKS 264 Intake and Exhaust Cams
New timing belt and oem idler/Tensioner 1,127 miles
3rd Gen lifters Saa
Oem Valve Cover/ With Boostx Coil on Plug Set up
Induction / Exhaust system:
FP ported EVO3 Turbo
K&N filter
custom front mount intercooler
Aluminum Intercooler piping
Ported 2G Oxy gen sensor Housing Housing
CME 2.5 in Turbo back stainless steel exhaust modified with Vibrant Resonator
Ported EVO 3 Exhaust manifold
New Exhaust manifold and o2 heat shields
Fuel:
PTE 650 cc Fuel Injectors 1,127 Miles
Walbro internal 255 fuel pump
Buschur/ SX FPR
Drivetrain:
4bolt rear diff
Stock Rebuilt Trans Just over 13,000 Miles Rebuilt same time as Engine
Stock Rebuild Transfer case Same as Above
Rebuilt Drive Shaft assembly 2 carrier bearings all shims and 3 u joints Same as above
Fidanza Flywheel New Friction Surface 1,127 Miles
ACT 2600 Clutch set up with stainless clutch line
Rebuilt Clutch Pedal Assembly with oem Bushings
Rebuilt 1g shifter assembly
Brakes/suspension/wheels:
Stock Rebuilt Calipers
Carbon Brake Pads and replaced all 8 brake lines 1,127 miles
Mitsu Galant specific rims17x7.5" 35 mm offset Does not require hub centric rings
Hankook V10 tires 215/45/17 1,127 miles
BC Coilovers
All new wheel Bearings with seals .1,127 miles
Other items replaced 1,127 ago New radiator,all drive belts, Brake Master cyl, and new master to reservoir hoses, Clutch Master and Slave cylinders Spark Plugs,Rebuilt1g Rack and Pinion New tie rod ends ,New Front Ball Joints NewFront and rear subframe bushing spacers New 02 sensor,Knock Sensor ,Coolant Temp sensor, Rad fan Temp sensor, stainless steel ofh to turbo oil feed line, New cam seals and Rear main Seal.New Trans mount passanger side and Prothane Drivers side Note Saa = same as above
Power:
Currently 272 hp and 278 TQ at the wheels 17 psi Mustang Dyno @ Central Florida Turbo NO Tuning Except for DSM stage 3 Chip with EVO 8 MAS.
Almost forgot Price lowered to $6,900 obo Now for The bad car has faded clear coat on hood and roof, some minor dents.
dsm5062
Member
ocean city,md
would you be willing to travel any, maybe meet me halfway? I am seriously interested in the car and have money, just cant drive from maryland down there with my schedule.
got_psi
Member
Metro Detroit,MI
Yo will u sell roller? I have no use for that motor nor is it my style I have built running 4g63t just begging to call a super clean GVR4 engine bay home /ubbthreads/images/graemlins/rofl.gif
G
zompton
Looks clean, please don't send it to it's death in il or mi.
dmj
orlando FL
I rather sell it cheaper to someone who is familiar with these cars, than get paid more by someone who is going to hack it. I am vetting potential buyers,seriously . For all those folks sending pm's yes the car has nice cold AC.The p/w mirrors and cruise control all intact and functioning as it should. I have receipts for most parts replaced.
G
zompton
I was referring to the salt. /ubbthreads/images/graemlins/rofl.gif Because you know these knuckleheads will drive it in the winter.
drew367
Member
Elgin, IL
"Knuckleheads"? That's sweet. If only all of us could afford NOT to drive their cars in the winter.
God bless those who can; I'm not one of them. Not even sure I wish I was.
G:"Sh*ts on Everything" - makes perfect sense.
Think better of the rest of us next time.
