I have a belize green vr4 project that im lookng to sell. I have had the car for a a little bit then took it apart to rebuild and its been sitting since. I haven't had the time to get it back together and at this point the main reason i want it gone is so i can get the garage space back. Id prefer to sell it to someone who wants to finish it rather then part it but whatever. It needs a little bit of work to get it going. I started some body work a while back so the car looks like a mess. I did plan on spraying the car so I have a gallon of Belize Green paint. Heres a quick mod list off the top of my head, ill get more detailed as I go over the car. Ill add some pics tomorrow. Driveshaft and t-case need to be installed. Im looking to get $5000.
-Engine-was rebuilt years ago and never ran, i check the walls with a borescope and they still look clean but someone might still want to give it a once over
-Ross pistons (bored 20)
-Eagle rods
-ARP hardware
-Metal Headgasket, either Mitsu or HKS
-New pump and belt hardware, gates belt
-BC 280 cams
-BC springs/retainers
-90 style oil cooler housing, needs cooler
-Drivetrain
-Turbotrix transmission with welded front diff
-ACT 2900 clutch
-either JUN or Fidanza flywheel
-low mile FP 3065 turbo
-FP cast manifold
-Tial 44 mm Wastegate
-FP 4" cast intake with almost new Green filter
-3" turboback exhaust
-New AEM 320 pump
-RC 950 injectors
-Aeromotive FPR
-New ebay afco stlye radiator with gates hoses
-I also have a new mishimoto 1g rad if you wanted to try and fit it in
-Poly motor mounts
-Kosei K1 wheels, tires are shot
-ECM link V3
-Dejon Tool intake manifold
-Buschur 1g FMIC kit that i started to install, trimmed front support to make it fit
-Tial 50mm BOV
-solid bushings for driveshaft and shifter cables
-Eagle rods
-ARP hardware
-BC 280 cams
-Drivetrain
-ACT 2900 clutch
-FP cast manifold
-New AEM 320 pump
-RC 950 injectors
-Aeromotive FPR
-Poly motor mounts
-ECM link V3
-Tial 50mm BOV
