1992 Mitsubishi Galant VR4, very, very rare car
One of only 1,000 made
Extensive and expensive work has been done to this car to make the ultimate all-wheel drive monster.
Built for autocross, but able to drive everyday. Familiy commitments have taken away time to Autocross.
This car deserves to be driven. Now is your chance!!
Over $20,000 invested, only the best parts went into this build.
Leather interior, moonroof
-Engine mods-
Eagle H-Beam Rods
Weisco 9:1 Pistons W/coated skirts
Clevlite Bearings
Balance shafts removed
Cometic MLS head gasket
ARP main studs
ARP rod bolts
ARP Head studs
Completly spin balanced bottom end
1MM oversized supertech valves
Crower Valve springs and retainers
HKS 272 degree cams
Unortodox Underdrive pulleys
Fidanza adjustable cam gears
Greddy Timing belt
ALL new OEM oil and water pump and all timing belt pulleys.
90 Oil Filter housing with external oil cooler
Mobil 1 was used after the intial break-in period
Motor was built by performance engine and machine in madison, WI and assembled by JA-Spec Engineering
Mitsubishi BIG 16g with upgraded flapper. NOT an EVO 3 16g
Ported 2g Exhaust manifold
Ported 1g 02 Housing
K@N Filter with custom intake pipe
Full 3" Bushcur SS Exhaust system
Magnus Intake manifold
BBK Throttle body with JA-Spec engineering IAC Adapter
Prothane Motor Mounts
JA-Spec Engineering Coil on Plug System
Extreme intercoolers custom race core front mount and complete piping with t-bolts
1G Blow off valve
Perrin performance catch can
SRP Boost controller (manual)
-Fuel System/Electronics-
GVR4 Chipped ECU with all the good stuff
750cc RC engineering injectors
Walbro 255 Fuel pump, with RE-WIRE kit
GM 3" MAF
MAF Translator Located in the center console
AEM Wide band Gauge and sensor
30-30 psi boost gauge Autometer
Apexi turbo timer
-Drivetrain/suspension-
ACT Exact Flywheel
ACT 2600 Clutch kit
New clutch master and slave clyinder w/ extended push rod
Shepherd stage 3 transmission with 4-spider center diff and all the other goodies (red line shock proof oil)
4 wheel steering removed
4 Bolt LSD Rear End
Cross Drilled and slotted rotors
Braided stainless steel brake lines
ALL poly urathane suspension bushings
KYB AGX Shocks
Ei bach pro kit front springs with 1g awd rear springs
All new calipers
Engals Rear upper adjustable control arms
2 sets of rims and tires
-Misc-
JA-Spec engineering Batteryh relocation kit with 250 amp fuse
Custom Gauge bezels
Car has around 400 hp and is cable of much much more!
Selling for $7,900 Less than 1/2 the cost to build.
Email with questions.
-Engine mods-
Eagle H-Beam Rods
Clevlite Bearings
ARP main studs
ARP rod bolts
ARP Head studs
HKS 272 degree cams
Greddy Timing belt
1G Blow off valve
GM 3" MAF
Apexi turbo timer
ACT Exact Flywheel
ACT 2600 Clutch kit
4 Bolt LSD Rear End
KYB AGX Shocks
All new calipers
-Misc-
Custom Gauge bezels
