kjbtsi6686
Active member
I am selling my 1974 Pinzgauer. 30,000 km. This is a very clean and dry low mile Pinz. It has a Tuff River insulated top, Scat bucket seats in front with 4 point harnesses. I have installed e-track in the rear and it has 4 e-track seat belts as well in the back.
Will need tires, has a oil leak from around the oil pan and a weep from the front axle pivot ball joints. It will also need the windshield wiper motor rebuilt or replaced.
Really dry , only areas I found are the drivers side of the windshield frame, a small bit left bottom of rear hatch and one spot under one of the rear seats.
It comes with new seals for the axle pivot ball joints and oil pan as well as 2 oem oil filters, a set of front axle fill/drain plugs to replace the factory allen ones with bolt heads and 2 cans of swiss army green paint. I also have the original pintle style rear hitch that will go with it. I also have a milk crate full of the original tops hardware that goes with it as well.
2.5L Aircooled motor runs like a top, it has been converted to civilian ignition with electronic points.
All of the lockers work without issue and this thing is a beast offroad.
Asking $14,000
No trades
Clear New Mexico title in hand
