FS: 1261/2000 Newark, NY 5,000 Bo
497of2000
Member
palmyra,Ny
This is 1261/2000 pretty solid shell
Here is list of goodies
- dsm link v3 full
- full race ported head and polish
- crower stage 2 264/272 cams
- evo8 double valve springs
- supertech inconnel +1mm exh valves
- supertech +.5mm int valves
- fabricated Alum intake manifold
- fuel lab ape with bradied lines
- no name fuel rail with fic 850s
- Manley rods
- 2.3 striker kit
- crower adjustable cam gears
- ets intercooler setup
- stage 5 comp clutch with modified pressure plate
-t67 turbo
- mishimoto radiator and fans
-aem boost,oil and wideband gauges all digital
- brand new toyo ra1 tires with less than 200 miles on stock wheels
- bc racing coil overs
- aeromotive 340 lph fuel pump with new hanger
- complete spare 4 bolt rear with axles to go with it along with another tranny and 2 transfercases
Car runs decent will need a professional tune to get most out of it iam currently running 21 psi and I'd pulls pretty good. Everything works on this car horn sunroof all the windows interior is 8/10
Car does not have power steering or ac
Per the rules to sell a car here:
5. At least one clear photo of the actual car for sale is required. If you are serious about selling your vehicle, this should not be a problem.
People are going to want pictures of the typical rust problem areas on a car from NY, so you might want to just post those up now before people ask.
gazoo92
New member
Indianapolis IN
Hey , I have a Eclipse 4g63 everything working but I would like to have a vr4,where I come from we Don't use heat in our cars but I recently Moved to the US with that said I am not a mechanic but I am interested in this car,When a Car does not have AC it means there is no HVAC neither right and no defrost on windows? How Hard would it be to put the A/C back to work??
