Freeze plug removal
971of1000
joplin, mo
I have a couple of freeze plugs that have pushed out a little and causing some leaks. I am trying to get them out and have had a lot of trouble. Any ne messed with them before? They are on the back of motor, head is off.
Screwdriver + hammer, knock it sideways. Use pliers to yank out once sideways.
Galantvr41062
plymouth, MN
As said above, then when you install the new ones put a little black or gray RTV around the sealing surface, then hammer them in using a big socket as straight as you can.
~John
Hammer gently, least you knock it slam back into the water jacket. Not that I've ever done that or anything... of course..
971of1000
joplin, mo
Yeah got one of them done. The other one that is leaking is not budging. I am going to work on it more today
With it getting warmer outside, you can cheat a little bit by popping the new freeze plugs in a freezer for a while before installing. Seems to help when using RTV on them, since the sealer is not as prone to being wiped off upon insertion.
If you have it, use a bearing/race driver, the lip on the tool will keep you from driving the new plug into the water jacket.
