found some chassis stuff
turboaddict
Omaha, NE
go down to mitsubishi ten to galant vr4.
I tried to copy it directly but didnt work so there you go.
Fender braces? You gotta be kidding me, I really didn't think anyone would ever make these! now all I need is some points.
Are those Fender braces an improvement for handling or something?? /ubbthreads/images/graemlins/blush.gif
Supposedly the braces are supposed to anchor the A pillar to the front frame rail. The effect is to make the front end frame stiffer, combined with a strut bar it should link the A pillars down to the struts then tie it all together. I have heard on the S2k's there is an improvement, but no one has really tested them. In theory they should work, but theories are just theories.
bazeng
Melbourne, Australia
I have these.
I haven't installed them yet...
I have noticed that the body does FLEX alot when jacking the car up.
If I were to install these, I'd weld them in.
Now in saying that, the later model evo's had these out of the factory
