Foam or sealant for the fireware
Hondasi88
MD/NOVA
I just finished re-doing my shifter cables. I put all my nuts and bolts and rubber pieces for the cables in a box that my son decided to put out for the trash man. My question is this...I found all the bolts in crap through a junkyard sweep but i don't have the rubber or bracket for the firewall. Now, all the fumes is getting into the car from the engine bay. Is there some automotive foam or sealant i could buy from advanced or pepboy?
JNR
ca
Usually the foam (especially) and sealants are almost too flexible, but can work in a pinch. Personally, I'd look for a grommet that is the proper size and they do make the kind that have a slit to wrap around the cable, although the better way is to remove the cable end, slide the grommet over that until you reach the firewall. Probably should emulate a baracket if you can't find an oem stocker, just to keep everything nice and secure (there's a decent movement inside that will probably have it flop around to an extent).
Hondasi88
MD/NOVA
ima just hit the junk yard again and look for a replacement....its only the rubber and some bolts.
JNR
ca
That would be the best bet...just check to be sure the rubber isn't cracked or extra brittle...silicone lubricant/spray works great to keep rubber supple and bring it back to life (within reason), fwiw. You can also use dielectric grease, but do not use vaseline, as that will not be compatible.
