flywheel torque specs
BENE38A
New Zealand
hi my flywheel was just skimmed and ready to be installed, im using some red threadlock, can i re-use the bolts?they appear fine and what are the torque specs its a standard flywheel also i will clear all old threadlocker to achieve correct specs
fuel
Toronto, ON, Canada
yes you can reuse the bolts so long as the threads have not stretched. I always clean up the threads with a rag and then run the bolts in and out of the threads a few times and clean every time they come out. Flywheel to crank bolt torque is 98ft.lbs
