Flywheel issue
Ok so 1501 is being worked on by a teacher and his class who is farther along than me. question is I thought the clutch was slipping so I got a new one they pulled it out and told me the old clutch is good. but the flywheel was a little bad so they sent it off to get machined. Will that make the clutch slip or should I look for something else the teacher is an A. S.E. maser tech so he is telling me its fine and wont slip. He also said something about being a stepped flywheel it will actually be tighter this time. Could it be the linkage or fork that makes it slip if it slips this time. Just thinking because I saw a thread about something mounted wrong by the fork and was making it slip.
Terry Posten
Davenport, Iowa USA
The flywheel is stepped down. Most clutches requuire a .610-.620 step. But call your clutch manufacturer for the correct step fot the clutch disc and pressure plate.
