finally got a power run on the vr4
NZ VR4 RS
new zealand
had the car on the dyno at spec a few weeks ago to get a power figure as i have been wanting
to know how the new setup was making the power.like to say thanks to jon for coming down on a sat morning just to run the car up.
the 35/40 has been on the car for just over a year now and has dropped the 1/4 mile time from 12.3 after it was first done to a 11.75 last month.
car made 235kw on the 16g at around 24psi and ran a 12.2 so was looking at how much more it took to run the 11.75.
the 35/40 was running 24psi and was on avgas the main problem is one i have been chasing ever since the turbo went on is that on part and cruise throttle the car will dive to massive richness.
after swapping everythig i could think of over i think it must be a broken or loose wire in the afm system some where,with the link going on soon this should sort out this major issue.
the power figure while i feel is a bit light for a 35/40 at 24psi even on a stock motor i think the fuelling issues had a bit to play in it.
ended up with 259kw which makes me and the car look good with a couple of 120mph passes.
you can hear the car go rich at the start of the pull.
