fan override switch
What would be the easiest way to tackle this? I want stock radiator fan functionality retained for both my AC (pusher) and radiator (puller). I'm going to install a 180* thermostat so I just want to wire in a switch to flip the fans on when in stop/go traffic or waiting in the staging lanes at the track. My coolant temps are perfectly normal for a stock car, but I'd like to get them down a bit during those driving conditions. I'm sure all I have to do is run a wire to the fan relays, but I'm not sure if I should go to the relays or to some random wire under the hood that's maybe easier to access. Anybody else done this?
Jason G.
Anderson, SC
IIRC, the single wire sensor on the back side of the t-stat housing closest to the cylinder head will run both fans when grounded.
Maybe wire in a switch there?
mitsuturbo
Near Seattle, Washington
Quoting Jason G.:
This is precisely what i'd do. If you're worried about the factory function of that temp switch, leave it plugged in, and simply tap in a wire that will go to switch. Wire the switch to ground. Enjoy.
toybreaker
iconoclast
Quoting Jason G.:
... fwiw, this will also kick off the a/c compressor
Thx guys. Looks like I have a little project for the weekend. /ubbthreads/images/graemlins/smile.gif
I went and looked in the engine bay. Rather than run a wire all the way to the thermostat housing to tap that wire, is there a place closer to the fuse box under the hood that it's accessible? I did pull that wire off the switch to confirm that it turns on both fans when grounded, so I just need to find a closer place to tap into it.
