Exhaust manifold Studs
Yes, I've searched. Read about the BMW studs and saturn studs. My questions are:
Are stainless steel studs really better? (more of an opinion)
and
What about using stainless studs with OEM copper lock nuts? Would they slip or corrode?
I ask about using the OEM nuts because the have a built in washer and the lock. Also from my searching I found the site ssstuds.com and they offer a stainless stud with copper nut combo. So is it better, what are the advantages and disadvantages of copper on stainless, and using stainless on stainless?
CutlassJim
Manchester, NH
I went with the full SS 2G set when I was putting 797 together 3 years ago and they are now the only thing in the car not rusted and came off super easy.
GreenGSX
Rochester, New York
The One Lap VR4 uses stock studs with stainless flat washers and stainless nuts. I torque them down, heat cycle them a for a few days and then snug them up again. Haven't broken a stud or lost a nut in years. The important part is to brace the down pipe to the block. I welded a tab on mine that I connect to the factory point.
Dan D
Brownsburg, IN
My vote is for oem studs and nuts with all the holes reworked with a timesert. Did that many years ago and haven't had a problem with loose, broken or stuck hardware since.
