EVO 3 radiator in your vr4
Bonecollector
Member
In The Woods, AZ
Anyone here using an evo-3 radiator in their galant vr4?
Aside from the overflow nipple on the filler neck being a different orientation and the temp sensor bung not being there (on some brands) the evo 3 radiator looks pretty close to being a direct fit.
my main worry is the mounting tabs being off.
If there is someone using one, and can drop some installed photos i'd appreciate it.
JSchleim18
Long Island, NY
I have a Koyo Evo 3 radiator installed. I relocated the temp sensor to the thermostat housing and you'll see how I routed the coolant line to the reservoir. It's pretty straightforward and looks great installed.
Bonecollector
Member
In The Woods, AZ
Thanks for the replay.
Do you think it would fit with the factory intercooler bracket?
Koyo doesn't make an evo3 rad option anymore, but I've been seeing several evo 3 radiators on eBay in the $150 range
moduleunknown
Elk Grove, CA
I also have a Koyo Evo III radiator. My overflow line route is similar (not much else you can do unless you move the tank).
I went a different route with the sensor and had a bung welded on in the stock location.
Other minor tweak was that I had to grind down the fan mounting standoffs on the driver side (not needed anyway) so they wouldn't hit my ETS intercooler piping.
Other than that, the radiator dropped right it.
Bonecollector
Member
In The Woods, AZ
@moduleunknown
Is that the 14" flex-a-lite fan that you're using?
The koyo radiators look pretty thick, were they 3 row?
I emailed GPI Racing to see if they would build me a radiator, mainly so i won't have to weld a bung. I'm using their radiators on my 01 Honda cr250 and have been working great, and really the only option as of right now.
moduleunknown
Elk Grove, CA
Bonecollector
Member
In The Woods, AZ
@Bonecollector
It's a 12" FAL123 (with the logo plate flipped) - https://flex-a-lite.com/12-1-8-inch-lo-profile-s-blade-puller-electric-fan.html
I'm also still running the stock pusher fan.
As for the Koyo, mine is the 2-row 48mm core - HH030561 ...but there was a 53mm race core option (also NLA).
At the time I installed everything, I was living in Chandler, AZ and I can tell you that the setup worked great running around the desert on 120+ days.
That baby fits perfect.
I ran the flex-a-lite 420 fans on my old talon, which is basically a double fan version of yours (i was living in Peoria, AZ at the time i owned that car) only really had to turn on the second fan when stuck in traffic on a "death day", some days would be so f***ing hot my laptop would just overheat and shut off, the car would be perfectly fine tho, lol.
I don't miss that at all, sucks that dual fan setup won't fit on the galant.
I've decided to stick with flex-a-lite but go with their "flex-wave" 14" fan this time, that fan moves 650cfm more than the 12" single shrouded with a 1.5 lower amp draw, and it's about half the cost right now.
I'm a little suspect on the depth fitment, the 12" shrouded fan you're using is 7/8" thinner than the flex-wave, so that will the determined here soon.
KiNgMaRtY
Corona, CA
I also have a Koyo Evo III radiator. One other thing to note is that it does sit a little lower than the OEM unit. Use can can just wedge something under or add shims to push it up. Other than that, it fits great.
Bonecollector
Member
In The Woods, AZ
Yeah, i just found that out, lol. I recieved the GPI radiator in the mail a couple weeks ago, which is also shorter by about 1".
What did you use for your spacer?
