evo 3 center diff
fuel
Toronto, ON, Canada
should be the same (ie 50/50 split and viscous coupler).. assuming it even fits - I believe gear profile is slightly different.
If you could find a Cusco Evo1-3 tarmac 65:35 center diff on the other hand...
123abc
Winona, MN
Depending on what VR4 you have, it would have a different tooth count on the outside of the center diff.
Olson
Moreno Valley CA
Quoting 123abc:
've got a US spec galant sitting at home
123abc
Winona, MN
It would have a different final drive ratio therefor different tooth count on the center diff.
gtluke
dirty jersey
There's 3 different center diff's you can have, you can tell by the grooves cut into the teeth for identification. No grooves, 1 groove, and 2 groves. the tooth count is the same on all of them, but the pitch of the teeth is different. Though IIRC the evo3 trans is totally unique and may be even more different.
