EGT Problem
birdman24
Cleveland, Ohio
Hello all I am new to Galants and owning a performance car so I will probably post some of the oddest questions on the forum unless someone has already asked it.
Last night while sitting in 1471/2000 I noticed my EGT gauge was reading below zero, I turned the car off and the gauge went to its resting point (zero) and when i turn the accessories on the gauge shoots back down below zero and stays there even while the engine is running. I'm guessing that the gauge has a short in the wiring some where, but I figured it would be smarter to ask the knowledgeable people of this forum first before i start ripping my interior apart. I am assuming that this is not normal. Has anyone experienced this before? Do I need a new EGT gauge and wiring?
Thanks,
Terence
birdman24
Cleveland, Ohio
Ok, so I removed the sensor and tried it again, the gauge read zero the whole time so I noticed that the sensor had a white tint to it so I wiped it down and stuck it back in. Gladly it works again now. Thanks
Struc
Oconomowoc, WI
It will probably go bad again, though. The sensors only last so long before they go fruity. I'd start looking for a replacement to have on hand. I like the TRE EGT probes, but it doesn't look like they sell them anymore. /ubbthreads/images/graemlins/frown.gif
