ecu question/ check engine light question
nickbuilt
queens, ny
would running a 92 eclipse eprom ecu in my 91 gvr4 give me a check engine light?? also what step do i have to take to read the code to find out what the check engine light is??? when i am giving the car gas check engine light goes away and once car starts to decel or at idle check engine light re-appears any help???
-nick
mooserage
Seattle, WA
To answer one question, here is how to check the codes: vfaq.com
Try using the search function next time for common questions like this one, such as a search for: +engine +check +code
Some of the other guys should be able to help with the rest of the problems, good luck man.
-shamus
Edit: on second thought, sounds kinda like when my TPS wasn't set correctly...
A DSM ECU shouldn't cause a CEL. You will run a little lean at idle, at least until the LOW TRIM richens it up, because the GVR-4 has a missing honeycomb in the MAS. But, other than that a 1991-94 DSM ECU will run fine. If its a 1990 DSM ECU you need to swap pins 6 & 14 in the harness.
nickbuilt
queens, ny
hey keydiver what might you think it sounds like why the check engine light shuts on and off with accel and deccel ??? and so on an so fourth???
-nick
Nate
Worcester, Pa
It's going to be very tough for Jeff to guess what's causing that light without more information.
I'd check to make sure the TPS is adjusted correctly. From what I remember, the ECU seeing sensor voltages other than what it expects during the conditions it's seeing are what cause it to light the CEL. Time to break out the voltmeter or datalogger and check/adjust accordingly.
