ecu mount
Brunoboy
San Bruno,CA Home of SFO
anyone have a diagram of this? Im pretty sure my new ecu wont fit, because the tabs dont look like they line up. BUT I bought my car with the ecu under the passenger side floor mat so havent really figured out where it goes. Just wondering if anyone has a picture, and if anyone is using a eclipse ecu how did you put it where you did? Thanks
-shane
The ECU's are both the same however the case around the ecu is different in the sense that the Galant ECU housing has different mounting tabs. I'm sure if you search around here or other dsm sites you can find a photo comparison.
The Galant ECU just has 2 prongs that stick out the top, to guide it into the top mount, and 2 round holes at the bottom, to bolt it to the chassis. You can see part of the 2 rubber top guides in this picture:
For Sale ECU
Ahhhh! Here's a better set of pictures:
Another For Sale
Brunoboy
i think imma drill off the tabs on mine and make brackets to bolt it up there... -_- thanks for the help, i am just tired of people stepping on it
strokin4dr
Savannah, GA
Just go in the junk yard and pull an ecu out of any base model galant (or even early mirage and some other models), take the ecu board out and just buy the case. Then bolt your ecu board in it and be done with it. Why go through the trouble of hacking up an eclipse case to make it work when the correct case can be found cheap and easily???
