ECM link v3 full VS Evoflash (stock evo ecu) VS Autronic SMC
bazeng
Melbourne, Australia
Hi Guys,
Anybody have any feedback on the subject?
I'm only really experienced with the Autronic ecu.
Pros:
1. No afm
2. Easy to log and tune
Cons:
1. No knock control
Any input on the other 2 ecus?
Since switching to ECMlink V3 I absolutely love it. The ease of use and amount of things you can do is amazing for a stock based ECU setup.
EHmotorsports
Beaverton
I agree ECMlink is the way to go. You can ditch the afm/maf/mas and run a map in SD mode. Well worth it.
asmo
SLC, Ut
If your going speed density, why not use DS-map its a lot cheaper, almost free, the parts to convert to sd is the only cost.
I pretty sure nate has been using it on his.
EMX5636
Bucks County, PA
DS-Map was an awesome setup, but I think V3 has surpassed it now. There is a ton of user support with ECMLink and people have used them up to around 1000whp. I'm sure the Autronic has a few more features (like AEM here), but it's more expensive, and I don't think it's needed in most cars. My car with V3 drives like stock, starts and idles like stock (minus cam lope, but no stalling etc) and makes 500whp on pump gas. Couple buddies have made 700-740whp with V3 on a street driven car.
Knock control on a race motor isn't really worth a damn. The guy who helps tune my car turns off the control on most cars that aren't going to see pump gas or the street. He can tune more with "knock ears" then letting the computer find noised from forged pistons, solid valvetrain/mounts etc. I wouldn't let that be a deciding factor if it's for your T51R car.
citymunky
Chesapeake, VA
I use DSmap (Jackal version 5), but the last time I played with it was over 1 year ago. Since then he released the Werewolf version (cell tracking, sensors control, better logging, press based vs load based, etc), however Werewolf is not free it's $199.99 for the program. My total cost into DSmaps was about $225 to $230 (not counting my LC-1 wideband) and it was much better that the SAFC, Keydiver, MAFT that was installed before I sold it to fund my DSmap setup.
Nate did use Jackal version 4 to get into the 10's, but switched to ECMlink for faster logging.
EMX5636
Bucks County, PA
If you want it to drive stock... my order is V3 Full, Evo ECU, then stand-alone. I have built/driven some AEM and Haltech powered cars that drove really nicely, but there is a lot more time in setup compared to V3 for a daily car.
