DRIVER SIDE E-BRAKE CABLE
MellowVR4
Milwaukee, Wi
Ok im replacing my calipers and i cant get the e-brake cable on the caliper. it wont let me pull it far enough to hook it up to the caliper. i dont know if i need a new one or i just need to mess around with the cable a little bit to free it up. not sure let me know please, thnx.
Rausch
Cleveland, OH
Have you adjusted it at the handle at all?
It *should* return to the normal disengaged position on it's own, and take a touch of leverage to disconnect. If it's not returning all the way, it may be seizing.
Edit: Here is AN adjustment procedure:
Pull parking brake lever with a force of approximately 45 lbs. and count number of clicks. Lever stroke should be 5-7 clicks.
If parking brake lever stroke is not within specifications, proceed as follows:
Remove center console, then loosen adjusting nut on end of cable rod to free parking brake cable.
With engine idling, depress brake pedal several times and confirm that the pedal stroke stops changing. If pedal stroke stops changing, it indicates that automatic adjusting mechanism is functioning properly to adjust clearance between pads and disc to correct value.
Ensure parking lever on caliper side is in contact with the stopper.
Turn adjusting nut to adjust parking brake lever stroke to specified range. If number of brake lever notches engaged are less than specified value, cable has been pulled excessively and failure of the automatic adjuster mechanism may result.
After adjusting lever stroke, raise and support rear of vehicle. With parking brake lever released, turn rear wheels to ensure rear brakes are not dragging.
Ensure parking brake lever on caliper side is in contact with the stopper.
MellowVR4
Milwaukee, Wi
yea I tried messing with the ADJUSTER but it didnt make a difference. it might be getting seized but can i free it by messing with it
raptorWagon
Oak Harbor, WA
It's easy but just a PITA to get to the bolts under the heatshield above the driveshaft that hold the cable to the car. Can check out this thread where a member had a difficult time with a bolt as well as some tips for removal with pictures.
MellowVR4
Milwaukee, Wi
my heat shield was rusted out so i removed it, but i might play around with it to see if i can get it free before buying a new one. cause my passenger one works fine, /ubbthreads/images/graemlins/dunno.gif will see.
