Does this sound like a good combo for DD? suspension
stealthtt24
Orlando, FL
the rears already have h and r springs on kyb shocks, and I'm leaving the rears alone.
The front are trashed so I'm thinking brand new from rock auto kyb gr2s with used oem gvr4 springs. Sound good for daily duties?
Whoodoo
Binghamton, NY
Non-MR Evo suspension (the KYB setup) is killer for DD duties. Firm, but not harsh, well balanced, and cheap. Cant beat it.
KiNgMaRtY
Corona, CA
GR-2's ride well with OEM springs but that's just it. If you throw some aftermarket springs, you will kill them
stealthtt24
Orlando, FL
Looks like ill be using AGXs all the way around with h&rs in the rear and eibach prokits in the front. Now I just have to source some bump stops....
stealthtt24
Orlando, FL
Hmm, when I did a search I came up with a lot of people that have agxs with aftermarket springs with no problem. I'll see how it goes I guess.
stealthtt24
Orlando, FL
I'd prefer just the gr2/oem springs combo but with the car I'm receiving the agx/eibachs combo for free. And whatever is on the front now its garbage and bottoming the car out.
stealthtt24
Orlando, FL
Well ill be using the agxs it comes with for sure. The question is should I just keep the eibachs or pay $38 for oem springs and sell the eibachs... like I said only dd, no aggressive driving, I want comfort over performance.
iLLeffeKt vr-4
NYC
AGX's suck a$$. I went through 2 sets on my eclipse gsx in less than 10k miles and one set on the gvr4 in less than 3k miles. They might be ok with stock springs but I wouldn't even bother. The adjustment screw froze on two of the struts.
thecman02
Kalamazoo,MI
Put 40k on some AGX's with Whiteline springs no problem. All my adjusters work. With that being said, I'm going with hotbits some day.
stealthtt24
Orlando, FL
Just wanted to update... the AGX's I have are blown and make the car ride like doo doo with stock springs. Replacing the fronts only, for now, with GR2s with new strut mounts. OEM springs all the way around.
Tre3zy
South San Francisco, CA
here is my input KYB's are good on the H&R springs all around... putting some prokits on it in the front is a back idea... once i put prokits on mines then i blew my KYB's so i upgraded to some evo struts with evo teins on them... and it was great for daily duties and ride comfort... firm but not harsh... it absorbs the bumps like it should... now im on BC coilover and i gotta tell ya i miss those evo setup cause of its comfort...
stealthtt24
Orlando, FL
I have a set of evo 8 front and rears, they are going on the fp3065 car. This car is my DD and while Ill have some sprinted driving around the city, it will never see any track; just some long highway drives.
BrandonEchols
Anchorage, AK
So buy another set?
They can be had cheap as all get out, hell I've seen the MR Bilsteins gor for under $400 for all the entire set.
You can't really get better than that for a DD, particularly for the coin.
