Defi Link Installation
VR_IV_MR
Queens, NY
The DC Source wire coming out of Control Unit V2 has four wires and this is what it says in the manual:
RED : BATTERY (to 12V battery wire)
ORANGE : IGN (to 12V wire when ignition on)
WHITE : Illumination (to 12V wire when small lamp is on)
BLACK : GND (to ground, Negative battery terminal)
Here is the Link to the ECU PINOUT if anyone could tell me which wires I need to tap into.
Also, anyone that has used defi link before, would you be able to tell me whether the green wire or the blue wire given is used for the "TACHO" and also where would the remaining green/blue wire be used? (by the way, the green wire just ends as a wire whereas the blue wire has a funky thing attached to it.)
thanks everyone
slobra
Wilmington, De
I hooked my defi-link up to the wires behind the clock on the dash. If you look on the back of the clock it tells you which wire is 12v, ground, ect. I have my control unit in the pocket of my 89 dash and just took out the gauge cluster bezel and ran the wires up to where the clock is and soldered.
VR_IV_MR
Queens, NY
ok well my clock wires aren't labeled as you say they are but from my understanding it should go like this:
defi link : dash board
red : battery 12v : red w/ black stripe
orange : ignition : blue
white : illumination : green w/ white stripe
black : gND : ground
correct?
slobra
Wilmington, De
The back of the clock where the connector plugs into looks like this. The "1's" are the pins inside the back of the clock where the plug will plug into. So Acc is ignition, clock is 12v battery, earth is ground and Illumi is well, Illumination. I just soldered into these wires and it works fine. I would take a picture but its all white so nothing shows up.
__
Earth[11]Clock +
........[_1]Illumi +
........[_1]Acc +
spooling92vr4
long island, NY
i can give you a hand with it if your not confident to f*** with it. unfortunately i work alot and i wont be off until monday and tuesday next week
VR_IV_MR
Queens, NY
ok im sorry im kind of a newb i just have to double check before i go ahead with the install...
i can solder the ground wire into the earth wire behind the clock? i dont have to ground it to a nut or bolt on the chassis? which is more ideal?
