Debating on building head or whole engine?
Boostdtalon
Buckley, Wa.
ok the engine that is in 192 right now needs the head rebuilt. I have another engine i pulled from a GSX that i will be doing a full build on overtime. But right now i'm comtemplating having the extra head rebuilt and maybe tossing in some cams. than putting it on the engine thats in it now so i can drive it minus the smoke.this would allow me to drive the car and work on the other parts of the car for now. id rather put money into fixing paint, the interior and improving the suspension alot more than making power. i also want to get my turbo kit together so i can get rid of this stupid T25 that was put on by the previos owner after his holset blew it's center cartridge. it has a punishment racing O2 dump that opens at 5 psi. I've juggled this around in my head enough and i guess i'm looking for opinions more than anything.
JSchleim18
Long Island, NY
As long as the bottom end is healthy I wouldn't touch it. If the balance shaft elimination hasn't been done you can do that now. Also, do the timing belt since the head is going to be off. Put some ARP headstuds and a Mitsu MLS headgasket on there and enjoy it.
+1, the bottom ends are capable of holding enough power for a DD. Jschleim covered the rest.
toybreaker
iconoclast
Do a leak down test before you tear it down.
If there's no appreciable leakage past the rings on an engine that's at operating temp, you're good to go.
Boostdtalon
Buckley, Wa.
Yeah I had plans to do the leak down test before hand. I'm going by the machine shop today to talk to them about getting the work done. Well the PO told
me the balance shafts had been removed and that it has ARP's. Guess I'll find out soon enough.
Boostdtalon
Buckley, Wa.
ok well i talked with the machine shop today and got a price for labor. Not a bad price at all. just need to acquire the parts for the head and get it to them.
