dammit... just got her rollin again...
Epifool
greencastle, In
Ok. Long story short- rear diff locked up last nite, thankfully less than 2 miles from home. All i wanna know is, does anyone have a good 4 bolt rear clip they wanna swap for a good rear clip with aws, all the parts are there on my spare car. Also, would like to hear from someone who has re-installed aws, need to know how hard/long that process was. Whoever said getting mitsu's and modding them, then using them for dd's was fun- that guy l /ubbthreads/images/graemlins/banghead.gified.. All input welcome!
toybreaker
iconoclast
... sure it isn;t the t-case that locked up?
Drop the driveshaft and see what's what before buying/swapping anything!
James
Port richey Florida
Man I must have the best luck ever. While I've never gone to far past the 350hp mark or the crazy mods mark... I've owned 10 turbo mitsus and zero of them have left me stranded or been JSB for more than a day
LIV4PSI
O-H-I-O
I don't understand what you are asking about reinstalling the 4WS. Just put the 4 bolt internals into your stock diff case, and done. It sounds like you want to swap to a DSM rear subframe and then reinstall all the 4WS stuff. If so, the mounting spots will be missing for several things.
Epifool
greencastle, In
Thanks toybreaker, i'd forgotten that. If it the tcase then no biggie, i have another. May save a few weeks downtime!!
If it winds up being the xfer case, figure out why it locked up. If it was lack of fluid, figure out where it leaked. If it leaked from the yoke, replace that sh*t with a recall yoke kit ASAP.
mitsuturbo
Near Seattle, Washington
Quoting epifool:
Don't be so sure. When a Tcase locks up, it can break a whole bunch of other sh*t along with it. Center diff for one. If it was the Tcase, you may have gotten lucky and that's all that broke, but more often than not at least one rear axles snaps as well (at least if it's a 3 bolt rear).
Epifool
greencastle, In
Well, if thats the case, i may just find somewhere to get her outta the weather, and pull the aws rear off 1025, and start assembling the pieces i lack to swap the front to 5 lug hubs (the rear on 1025 is swapped already, but the front bearings were bad on it, so i'll have to get new one) and pull the whole driveshaft. I guess al i can do is hope the transmission didnt get broke along with the tcase.
Epifool
greencastle, In
Just a question, for the guys who've seen the dark side of our cars... What all am i lookin at, as far as possible broken stuff? I know my xfer case leakd at the rear seal. Do i need to pull the cover off my rear diff now?
pot
Fayetteville, NC
Quoting mitsuturbo:
Quoting epifool:
That was exactly the case with me two years ago when my transfercase locked up. The output shaft was shredded as was the rear driver side axle. I pulled the diff cover and thoroughly cleaned the diff with purple power, brake cleaner, brush, and retractable magnet to pull all the bits of twisted metal.
Epifool
greencastle, In
Thanks for the additional info, Pot- i have a whole other driveshaft, tcase, and rear- the rear is an aws one, could i use that whole rear clip, without the aws lines, and other bits? I really just wanna drive it, dont matter if it turns at both ends!!
pot
Fayetteville, NC
No problem but thank mitsuturbo -I'm just adding to what he said. I understand you have several bits of hardware to install hoping to get you back on the road. To answer your question, yes, you can use the whole rear clip and simply connect your pre-existing hardware. However, the important thing to do is:
1.) Be patient and identify what caused your vehicle to lock up in the first place.
2.) I would suggest getting your vehicle jacked and suspend all four wheels the ground
3.) Perform a diagnostic check by hand spinning each wheel while looking/listening/feeling for an impediment
*This should help to narrow down whether this is the transfer case or the rear differential.
4.) Either focus your attention at resolving the concern or report back your results for assistance
