Crank Pulley Stuck
1295inthe303
Member
Aurora, CO
I'm in the process of a complete rebuild. Right as i go to do the balance shaft elimination i find that the bolt on the crank pulley will not break loose. I've soaked it with pb blaster and hit it with my impact... Nothing. Am i missing something? is it reverse threaded? Any suggestions?
AWDPower
Vacaville, CA
When they are real stuck like that, you need to do it the old fashioned way with a big cheater bar. I use a good 22mm socket, a good 24 inch long 1/2" extension, and a good 1/2" breaker bar. Support the extension with a jack or jack stand, and slip a 4 foot plus pipe over the handle of the breaker bar. Use your favorite method of holding the crank still. I put the tranny in fifth gear and have someone step on the brake. Use good quality tools or you will just break them. I used this method when even a high-end, 800+ ft lb. impact didn't work.
ercp98
northlake in illinois
what worked for me was heating that bolt for a long time with an acetylene torch, then right away hitting it
with an impact wrench.
mine had red thread locker on it.
1295inthe303
Member
Aurora, CO
Thanks for the advice guys. Unfortunately my motor is out of the car and id rather not have to make the tool to hold the crank still so i think i will try torching it first then give it another try. And its not reverse threaded correct?
SmoothCustomer
Lexington, KY
No, not reverse threaded. I'm assuming it's on a stand. You can thread in some flywheel bolts and stick a bar in there to hold the crank still.
yeti
san diego california
i had a friend hold the flywheel with a breaker bar and socket on one of the bolts, if you can i think i stuck a screw driver threw the flywheel...
SouthCaliVR4
North county San Diego
Find a bit of flat stock. drill two holes so you can bolt it down in a pair of head bolt locations. now place a large dia socket on the head of the piston so the bar stock will catch & stop the piston. This is known as a piston stop. you can break it loose & not harm the piston, rod or bearings.
Put a breaker bar on it and rest it on the front suspension arm. Then tap the starter a couple of times.
*edit* I guess if it's out of the car that method won't work.
desant78
Clarksboro, NJ
I put a solid bar in the crank in a way using two crank pulley bolts that it is putting pressure on the engine stand mount so it cant turn and get a large breaker bar and treat it a lesson.
yeti
Quoting turbowop:
This was my plan, but the battery was dead so i just pulled motor and had friend hold flywheel bolt
mitsuturbo
Near Seattle, Washington
Pull the oil pan if it's out of the car. Stick a handle in between the crank counterweights and the block. Twist away.
Don't go and do something stupid like only have pressure on ONE of the counterweights, though. Be sure and try to distribute the load across four of them.
Putting a screwdriver thru the flywheel usually buggers up the rear mainseal housing. Be careful about doing what Yeti suggested.
mitsuturbo
Quoting desant78:
This is also a good method. It's best to use longer bolts and make sure they're threaded pretty deep, so you dont screw up the threads in the ass end of the crankshaft.
