So here it is...another problem comes up right after I thought I`m almost done with the car. I`m getting fed up with fixing the po hack jobs and I`m afraid if I don't resolved soon, I might end up just selling the car as is.
The car was miss-firing bad and we traced it back to one of the coils. Getting a hold of a coil pack isn't the problem, it`s the wiring hack job the po did. He cut the old plug and crimped the wires to the plug that connects on the back side of the head. Now it looks like I have to do the same thing with the new coil pack. Now my question is, Is there anything that looks wrong with the diagram?
To my knowledge this is how it should be...
But my current set up is like this...
When I switched it to the right way before, my car would not idle right. I have been running the car with my "different" firing order for some time and it seems to work well. Why, I have no clue... But I would like to return or try to do it the right way. So I want to know if you guys can make out the wires and how it should be connected. Also, there is a plug that has no wire on the other end as you can see from the second pic. There is a wire that is just hanging with the same color combo, but I`m not sure if I should hook it up. Any replies or suggestions would be of great help. I need to get this car running soon because I`m getting to the point of just giving up on the project.
