clutch problems
Boos929
Active member
Mass
when I push my clutch all the way in I get a terrible grinding/clicking sound and it dogs out my rpms car still drives fine and noise goes away when clutch is half way out ....throwout bearing ? any other things it could be ? also ill be doing a clutch very soon anything I should replace while Im doing the clutch ?
SouthCaliVR4
North county San Diego
throw out bearing, clutch over extending & pressure plate fingers hitting disk even Crank walk. first check all bell housing bolts. Have a friend push on the clutch while you watch the bell housing to block gap for movement. a lot of time bolts back out & or where not reinstalled properly.
Boos929
Active member
Mass
it sounds like something that's rotating that's rubbing I just ordered a new clutch just wanna make sure I have everything I need to do the clutch any gaskets I should get ?
galant651
twin falls, idaho
you dont really need any gaskets but if you have the time and money i would recommend doing seals like the rear main, both transaxle seals and a pinion seal on the tcase.
Boos929
Active member
Mass
you wouldn't happen to know the part numbers for those seals would ya ? or a good place to order them through ?
