Clutch Hydraulic Line
GVR47111K
80022, CO
Mine sprung the most bitch ass size pinhole ever so I need a new one. I went to a couple of parts stores today looking for it with no such luck. I would like to avoid buying online if I could but I will if I have to, i.e. partsdino, dsmpartout, rockauto... A couple of questions:
Where can I find this part cheapest?
Mitsu part #?
Is it interchangeable with a 1G/2G?
How can I make this easier on myself in the future?
Thanks GVR4 dudes and dudettes.
rdomeck
Indianapolis, In.
I google this....I use a place similar to this in Indy and they are able to make any hose while I wait! You will have better luck having them make one from the master to the slave.
All that being said.....I would imagine having a line made of any length would run at least $100
DynastyLCD
Harwinton, CT
i like to replace that line with a 2g clutch line. not the entire line from the master to the slave, but the one to go from the framerail to the slave. just makes life a lot easier when replacing the clutch or working with the slave cylinder in any way. try this for size, Will!
