Clutch dragging
gvr4144
loveland Colorado
Well I was driving recently when my car started shifting like a turd. I revved it up in gear with the Clutch pushed in and the car started to move. So I know the clutch was fully disengaging. So I adjusted the it at the master and that did helped for a few days,but then it got to where I could barley get in gear and the clutch would grab at start up. I figured it was the master which I just replaced and no luck. I guess I'll try the slave, but my question is have you guys had the same symptoms with the slave? I still have high clutch pressure.
KiNgMaRtY
Corona, CA
It is a common issue with the GVR4's and the 1g's. It could be the slave, master or possibly even a worn pedal.
gvr4144
loveland Colorado
Okay, I have a slave coming tomorrow. I'm thinking it's that compared to a peddle with how quick it started. Where in the peddle system can it wear?
KiNgMaRtY
Corona, CA
When I pulled mine, I had Shepard rebuild mine. I believe JNZ will rebuild it if you don't want to do it yourself.
One way to test if it needs to be rebuild is press down on the pedal, now reach down and if you can pull it up anymore by hand than there is play and should be rebuilt. I attempted to pull mine up and it did not appear to have play but I sent it out to have it rebuilt anyway and it was shot still.
It definitely is not fun to pull it out.
Here is a little how to on DSMtuners click
Fish
Idaho Falls, ID
I had this issue with mine a few years ago. I replaced the master and slave cylinders. It was a little better but still hard to shift into gear. I ended up buying the 92 slave cylinder with the smaller bore and it's been perfect ever since.
