Clutch bleeding method
mikus
Aurora IL
I'm wondering which clutch bleeding method people prefer. I've seen every one of these recommended for this system on different forums, each w/ pros and cons.
- gravity bleed
- push once, hold & bleed, repeat
- pump, hold & bleed, repeat
- fluid line running to bleeder and just pump away with bleeder open
- power bleeder or vacuum bleeder
- 1-man bleed by pressing slave rod in under car and holding, open & close bleeder
and various others.. who knew there were so many ways to get fluid outta there.
I like to run a hose from the slave that is long enough to run back up to the master. start by pumping it into a bottle till you get clean fluid then put the hose back into the master. this way you can recirculate the fluid while the air works it's way out.
mikus
Aurora IL
^ and you just pedal away at it like that, until satisfied air is out? That's one of the better ideas I've heard yet for a one-man bleed.
yup, you can see any air bubles surfacing in the master. just use something to keep the hose in the master & dont hit the pedal too hard or the hose may kick off the slave.
VR4coop
Raynham, Ma
^^^ If it doesn't work that way, then you have other problems. Easiest way to do it. And replace every piece in your clutch system. slave, master, fork and pivot ball . It will be the best money you ever spent.
464/2K
Denver,Co
i think this is why our cars and dsm's are known for tranny problems, people never replace this stuff.
Nijasan
Gravette, AR
I just use a speed bleeder. Crack it open, clear tube up to a bottle with the end of the tube submerged in clean brake fluid.
Pump pedal by hand 10 times, add fluid to master. Check bottle.
Repeat until bottle is full, dump out, replace with clean, keep going until the fluid coming is clean. Tighten bleeder, top off reservoir on top of master, cap on master and you're done.
I just rebuilt my master cyl yesterday fwiw.
when i did mine i had to bleed it a few time, so do and drive it and see how it is..mine drove fine then a little while later i decided to bleed it again as it was kinda skicky..
