Closeout prices for the Galant on RockAuto
I tried to buy bearings, but the discount isn't the same for standard size, only over sized.
belize1334
Bozeman, MT
Someone with more money than me should buy all of those pistons. If I read that correctly, it's like $30 for a set of all four pistons and the necessary rings and 4 of the sets are 0.02" overbore. Also, somebody should grab those PCV valves cause somebody will want them at some point.
Beck/Arnley makes good stuff. Anybody doing a stock engine rebuild has it made with that list.
Quoting belize1334:
The Fram ones are crap though.
That price is per piston it looks like, I went through the entire check out, and it's described as Piston, not plural.
BoostedAWD91
Danville,Pa
i need to rebuild a engine, those parts good? ill have to call and see what exactly they have left. Its says only 2 left in standard bore and 4 in .020 over. i dont know if they mean there is only 2 pistons left or two sets left
I think what they are calling a "set" is one piston and its rings, not a set of four pistons.
Beck Arnley does make good stuff, I wouldn't hesitate to use their pistons, bearings, and gaskets if I was doing a stock rebuild.
fivestardsm
Middle, Michigan
Well that was a quick way to spend some hard earned cash..... /ubbthreads/images/graemlins/banghead.gif
The best part of it is, I was gonna get on there tonite and look for some parts anyway.
I saved up to 56% /ubbthreads/images/graemlins/jawdrop.gif, to bad not on all of it.
Score, just bought 80$ shipped worth of misc goodies. Then again most of it I bought knowing that if I hadn't it would break... /ubbthreads/images/graemlins/smirk.gif
Thanks for the heads up OP.
BoostedAWD91
Danville,Pa
nobody better buy those pistons, i need them and cant order them till friday /ubbthreads/images/graemlins/grin.gif
fivestardsm
Middle, Michigan
ARGHH!!!!!!! /ubbthreads/images/graemlins/mad.gif
I just got a message from rockauto.. They were all out of the main bearings that I ordered! Bastards /ubbthreads/images/graemlins/mad.gif
BTW, its not that they aren't going to carry the parts, its just one of Rockauto's suppliers warehouse isn't going to carry them anymore.
