Check engine light ?
Hondakiller
Deltona Florida
Ok the check engine light dose not come on when you first start the car. It will come on a little after the engine is started.
If you roll the throttle and at about 4k rpm the check engine light go's out and the car start to pull harder. Another thing it is doing. say your doing 40 mph in 4th gear rpm is at like 2k and steady. The motor will sputter. I'v looked over all the vacuum and ever thing seems in order. anyone have anyone ideals of what it might be? /ubbthreads/images/graemlins/banghead.gif
SouthCaliVR4
North county San Diego
It's probably because it's setting ohh... I dunno, a code. try reading the codes & see what it actually is rather than playing lets guess the possibilities via the interwebs.
SouthCaliVR4
Vfaq has a method for a test light or go to a shop with a compatible scanner & have them check codes it will cost less & save frustration in the long run. if all you wanted was a code read I'd only charge about forty bux to the Joe off the street.
Hondakiller
Deltona Florida
See the problem is the check engine light dose not come on when you first start the car. It comes on when you are driving it down the road. then it will turn off for a fem miles. then come back on.
my check engine light is set to notify me when my car sees any knock. Could your car do this.
And that sputtering is probably your bov leaking boost under load.
We need more info, is your car modded?
Hondakiller
Deltona Florida
It's mainly stock. I put a 16g, greddy turbo timer, scanmaster 3, FIAV block off plate, and a hbc boost controller. Update: forgot half size rad. I put a new head and all new timing parts on it.
Hondakiller
Deltona Florida
Sorry forgot to say. I noticed that the check engine light is only coming on during the day. when it like 90 degree out. The engine is not running hot or overheating. When it is cool out like 75 degree it love it no check engine light runs like a brand new car. I thank it just has a mind of its own. I have other plans for the car just hope it holds up for the time being. /ubbthreads/images/graemlins/grin.gif
BpuVR4
Chicago
sorry for bringing up old thread, but anything get resolved from this by chance?
