changed the clutch 4WS lights on?
Diego
So anyways got the clutch in got it around the block and it feels like the car is being pushed back while on the gas? Normal idk but I'm sure its not.... and then the 4WS light came on? Why? Does it come on because my passenger shock is bad?
Fill me in 1309 is alive but only 97% help me finish it.
14u2nV
Agency/St. Joe, MO
your post is confusing, but the clutch nor the shock have anything to do with the steering. Check your fluid level for that. As far as "pushed back"?, do you mean it feels like it's dragging?
Diego
Sorry kenny, uhm well when I turn my shocks turn with the tires.... shouldn't they stay in place and only the contol arm move the tires?....... yes it feels like its dragging, if I give it it gas of course it goes away, but then drags down again when off. clutch is Clutch Master fx100
Terry Posten
Davenport, Iowa USA
The front struts are clamped directly to the spindle/hub assembly. It will pivot with the hub when the tie rod is pushed or pulled. The top bearing plate has a bearing that allows the strut to spin.
If you take the axle out of the front hub, drop the tie rod, and remove the brake caliper, the whole hub/strut assembly should swivel freely suspended between the top bearing plate and bottom ball joint..
Diego
Ok understand terry, but my passenger side shock catches the fender well and pops and scatches.... and only when turning left it never happened til I had my passenger cv replaced after my tire came off.....
Terry help me... lol
Diego
So I just replaced my oild pan gasket cause it was leaking looks like I need a new oil pan too... fml. Well the oil pan has been gettin beat on by the cv shaft which I'm sure I now need to replace......... /ubbthreads/images/graemlins/banghead.gif
So I need a oil pan. 66.00 from factory
Cv shaft DS..... anyone here have it?
So I need to Figure why it hits still.... autobahntom has gr2 tht I will get
I'm so upset I could cry literally I put so much time into trying to bring back a raped car and still everything I do something else gives.... I'm sorry mods but FU*K. #amit.... the HG doesn't have 1000 miles on it....
Terry Posten
Davenport, Iowa USA
Are you having issues with the driverside axle? There is a inner shaft and an out shaft. The inner shaft has a bearing and bracket that bolts to the side of the block. Make sure those two bolts are good and tight. Also make sure that bearing is not shot.
Diego
all bolts on the DS cv including the littlt "L" bracket on the intermediate shaft have all been bolted up... everything is tight I triple checked everything before moving it and now i have a disaster... im going to the bank tmrw to see if i can get a loan to rebuild her AGAIN /ubbthreads/images/graemlins/uhh.gif... FML FML FML FML...... so that makes it 36 miles last year and well 7 miles this year. /ubbthreads/images/graemlins/uhh.gif.. agian im f'd on makin it to MOD in Normal this year because of this stupid BS...... /ubbthreads/images/graemlins/banghead.gif /ubbthreads/images/graemlins/banghead.gif /ubbthreads/images/graemlins/banghead.gif
