Cam Questions
MitsuDriver274
Bellingham, WA
So I may have made the mistake of buying a part before researching more into the matter. I picked up a set of Brian Crower 272's for 370 Shipped. Should have I gone with HKS bump sticks? I read somewhere out on the outerweb that the BC cams make more power, but I yet have to find and data on the fact.
alansupra94
Wayne,NJ
Looks like Webber camshafts basically suck /ubbthreads/images/graemlins/frown.gif
I am going to double check what exactly was in my car again. From my research, I know they are regrinds.
MitsuDriver274
Bellingham, WA
From those who have experience with em, how are they for a daily driver? I'm worried i'm going to have a hard time keeping it to idle.
Boostdtalon
Buckley, Wa.
if they are BC 272's than you wont have an issue with idle. I've seen them on a couple of DSM's and Evo's; all of them were daily driven cars.
AnotherNewb
Orlando, FL
Quoting alansupra94:
Does anyone have any problems with the regrinds? They seem cheap enough, but most of the time you get what you pay for. I know that the bottom of the lobe is cut but will the lash adjuster make up for that and what about the opening and closing events? Does anyone have a set that they can measure and compair to a NEW set? JW
Olson
Moreno Valley CA
Quoting The_Big_Weave:
I have BC 272s and I dont have a problem with Idle.
LOL I have 280s and it idles fine lol ... like a camed I4
H05TYL
Wgtn, NZ
Quoting AnotherNewb:
Nothing wrong with regrinds, I've got them in my car, the most commonly stated reason for not using them (surface hardness being removed causing them to wear excessively quickly) isn't an issue with our roller cam follower setup.
I'm not sure how much extra extension the lash adjusters have to cope with the reduced height "closed" portion of the cam lobe - Ideally you'd fit small shims under the lifters equal to the amount of material removed from the "closed" portion of the lobe - I haven't done this on my car and the rockers still seem to be held tightly to the cam. I haven't really driven the car in anger yet, so perhaps time will tell.
