bushing
evoquon
Active member
Cali
Anyone know where I can get a complete bushing kits for our galant?
Armitage
Herndon, VA
JNZ sells all the Energy Suspension bushings that are available for our cars. Note the DSM front swaybar bushing set from Energy DOES NOT fit our GVR4 stock swaybar. For the rear subframe and differential bushings you'll need to get in touch with Boostx or check if they're back in stock over at click
Keep in mind changing all the bushings is a HUGE project. I just finished all of them over the course of 6 months.
I'm assuming your refering to the suspension and subframe bushings. If so...
Unfortunately they don't make a complete kit from what I've read.
1g front subframe can be gotten from Energy Suspension and fit.
1g front and rear control arm bushings will work also. You can pick all of those up from ES. Whiteline/SuperPro make some VR4 specific ones, which are supposed to be geat. Someone that has them will probably chime in eventually. click
Boostx was selling some of the rear subframe bushings a while back. Not sure if he has any left.
curtis
Clarksville TN
click me.
Also get with John on the rear subframe
You can also address the front cross bar that the forward motor mount bolts to by buying a extra set of front subframe bushings. Kenny discovered thsi fact. Only other bushing not covered is the carrier bearing ones and I think a mustang sway bar bushing would work. Do a search undermy name and you'll find the write up Kenny started. I would do it but have to run.
What are the inserts that are separate on that website? What is the benefit of using them?
