I see that if you turn the Base fuel pressure up they can flow 1040cc Even at 800cc they will handle my 400whp goals I bet. Any reviews on these specific injectors?
You know our cars use low impedance right? AFIAK the resistor pack would have to be cut off and all wires (4?) soldered together to run high impedance. Any injector will flow with higher base, but why when the ecu is expecting 37? I don't see a reason to mess with this when you can buy any size/impedance injector set for $300 or less. I'd just sell them and buy some 1050's.
