bolt for the o2
Brunoboy
San Bruno,CA Home of SFO
on the o2 housing it has three bolts and one stud, The new turbo I bought has no stud, is there a place to get one? or has anyone done it a different way? I need to get the car assembled so if anyone has ideas thatd be great. thanks
-Shane
rdomeck
Indianapolis, In.
The stud does not have to have an unthreaded section in the middle. If you had a bolt with enough threads you could cut that head off and use it as a stud! The best way would be to find the right stud, but it sounds like your trying to get this together right now.
rdomeck
Indianapolis, In.
You don't have a way of cutting a bolt? Hack saw? Put a nut on it first, cut the bolt and back the nut off to clean up the threads! I believe the stud thread pitch is 10X1.25 You will find the normal thread for a 10mm is 1.5 You can sometimes find the 1.25 at PepBoyz! Good luck and if you don't have a hack saw and a vise....Go buy one now!
